reverse the track
In all honesty it is probably not something you should do because of the likelihood of decreased braking, and the benefits will probably disappoint you. If you are running the stock track, best thing to do is GET RID OF IT, because they really are horrible compared to the newer one inch designs from camoplast such as the predator (six pitch) or hacksaw. You will get the same or better top end with those tracks, and traction is night and day better.
you will hook up out the hole better, braking will suffer a little, BUT IT WILL HOOK UP A LOT BETTER ;)!
Thanks for all the info. I new what the Blue Devil was capable of. I bought one a 00 going through it right now. It's stock but I am putting turks set up on it www primary 4.5's in both holes a 51/43 with a red wound 70 degrese. Along with the worn parts I found. My plan is to whoop the shitaki shrooms out of every thing I line up with. More to come as I can Afford to build my devil. Again Thanks Gr8 site!!!!!!!!
Just remember there will always be a faster sled than yours some of the time.
That said, good luck man!!!
