Maxx Perf. Pri. Spring specs anyone?
Mars
Chelmsford, ON
Does anyone know what the specs were for an olive green spring going in a short cover YXR primary?
I can't seem to be able to find the Maxx-perf site no more.
By looking at it, it almost seems that it would coil bind in a short cover YXR, it's 1/2" longer than a G-P-G spring, and about a full inch longer than a W-P-W.
Ideas?
Is it simply green? I got the book sitting right here and on page 15 are the short cover springs.
I also have the 1.9MB 04 catalog in PDF format. PM me I'll email it to you.
Looking around a bit I found on page 14 the MaxxPerf springs YXRGRN has the following:
45KG Preload, 1.37KG/MM Rate, 90KG total force.
It is not like any Yamaha spring for the short cover. It has a lot more preload but a lower rate with a middle of the road total force.
That's the one!
Thanks.
It just seems like a long spring to fit in the short cover, I am a little afraid of coil bind.
