Troops
Click on the link to a great blog about snowmobile clutching. The guys name is Dynamo Joe. He is probably one of the most knwledgable Doo/TRA clutch tuners around. His info is about clutching the BRP TRA clutches but a lot of info pertains to clutching in any sled. Makes for great reading.
http://www.mxzx-revzone.com/iq.htm
JeepTherapy
great link, thanks
2003VIPERER
Great Link. Learned Alot Of New Things From That.
kysledneck
I will copy that! He seems to gear like I want to!
toddmod
now there's a lot of good information. must make a copy and read 10 times. I've read aaen's 1st couple editions. new information is a great referance. I've also learned a lot about clutching from Duane Watt. Anyone else ever talk w/ Duane?
srxeater
great stuff, thanks Turk
clandestiny
Damn they killed the link...
change_up
Yea... if you just type in www.mxzx-revzone.com and then you can click on the menu under Clutching IQ, you get some decent help. It's not the same page that it used to be that explained how the clutches worked... that was the one that got me into clutching as it really helped explain it. This one tells you how changes affect the performance but doesn't really explain why in a clear way I find. Happy I have the AAEN Clutching Handbook!
