bulkhead rivets
SR643
MI
Does anyone know where to get the rivets that hold the bulkhead to the tunnel? And how to install them?
thx
www.rivetsinstock.com
jay-cee sales & rivet inc. in Farmington, MI
is where I got mine. They sell about anything you want, just need to know what you want. They do sell in minimum quantities of 50-100+ depending on what you get.
How many do you need? I have extra of the structural "Q" rivets that are steel body/steel mandrel that I could sell ya. They aren't coated so if you are concerned about rust you may want to look for something else. I have yet to run with these installed so not sure how bad or if they will rust and become an issue?
You will need a phenumatic rivet gun, as I tried to pull them by hand with little to no success! Once set they are rock solid. Depending on your location and timing I might even loan you the tool?
If you search the FS adds you should come across the exact rivets I have.
Pretty flexible on cost, only looking to break even on them.
Good luck,
Al
