LightningPro
- Sep 10, 2003
Hey MrSled, what are those viper shock revalve specs?
Thanks in advance
Bob Flores
LightningPro
Thanks in advance
Bob Flores
LightningPro
ok bobby....LOL. the front ski shocks are set at 161 mm and have 142psi , center shocks are set at 120mm and have 284 psi and the rear are set at 186mm and have 284 psi in them. The set dimension is from the rim of the cylinder to the edge of the piston NOT the bottom most part of the piston. Take out 3 compressions shims and 1 rebound...that should be a good starting point for you. If you want more info on this contact Larry at NCY 715-453-2626. He might give you some more insight on the valving theory.
