Brake Rotor less rotating mass
yamyrider
Northern Ontario
anybody use this brake rotor. Is this the SLP.
Anybody know the weight savings. Thanks.
i have one on my viper. not sure on the weight reduction. every little bit helps but, when you put a price per pound lost, you'd be better off to lose a few extra pounds on your body than the sled. ski
its easier and more effective to lose rotating mass than go on a diet especially if your small anyways
well I am 6ft tall and only weight 180lbs so I can lose any.
If it is 2lbs less then stock then that is like 10lbs fo equivilant weight.
That sounds pretty good.
Hubs! These are Aluminum & for a Yamaha!! add these to a viper rotor should be lots lighter!
hmmm... looks like the 2005 mxz x rotor i was thinking of putting on my 99 SX..... may buy it yet, MUCH cheaper than the SLP rotor on e-bay... just wondering if the hub would work too? Might be a cheap alternative to the SLP rotor no?
better make sure, spacers, and jackshaft are the same size for that doo rotor. could be in for an expensive suprize, buying something not made for particular application. i have a non wave vented, lightend oem doo race 440 rotor in like new condition. not sure if it will work for your application or not. ski
