yamaha_snopro New member Joined Sep 8, 2005 Messages 200 Age 39 Location Northport, MI Nov 15, 2006 #1 cylinder heads need to be tightened to 17 psi, how about the cylinders to the crank case how many psi? this is for a 1997 sx vmax 600 twin, thanks.
FuzzButt New member Joined Dec 5, 2003 Messages 694 Location Waterford, Michigan Nov 15, 2006 #2 Wrong sort of. Following the pattern the top cylinder/head bolts are a 2 step 9.4 ft-lbs then 17 ft-lbs The cylinder/block is 24 ft-lbs Spark Plugs incendently are 14 ft-lbs, And the coolant drain bolt is 17 ft-lbs.
