Need A Little Lift
MICHAELSF150
NEWFOUNDLAND
Is there a kit i can buy or a mod i can do to get my 1998 vmax sitting a little higher on the back end? ive looked at some pics on this site and it looks like some are higher then others. thanks :dunno:
if your sled is an xt, not an xtc they your problem lies in your bushings. the xt sleds did not have bearings in the shock ends or in the rods that run along your rear shock.
all these bushings over time get tore up by the collars that rust. the best thing to do is to install the sx/srx/xtc/viper/rx style pro action collars and bearings in the shocks and arms. the front shock doesnt have them on any model, install these ones as well.
also, on that sled get a 2.3 rate spring for the center shock. rebuild the w arm as well.
look for my posts on suspension and it will give you a good starting point to make your sled better and last.
