Need advice on 02 Viper rear cooler
1badz
I bought an SXR exchanger to put in mine when I extend it to 136". I have the Viper rear cooler in there now, but I wanted a smaller one as I'm using a MM extension, and don't want the cooler extending below the extension. Will the SXR be sufficient?? Is the SRX and the Viper rear cooler the same size?? Anyone have a picture of the SRX one if they are different? The rear cooler on a MM 700 is alot smaller than the one that's now on the rear of the Viper so I'm thinking I may not need the largest one. I'm need it to be sufficient for trail riding, low snow conditions, etc.
As long as your viper isn't piped the SXR exchanger should be fine. SRX and later model Viper exhangers has better cooling capacity, but with the MM or SX exchanger you should be fine as long as you aren't in low snow conditions or have a few mods done.
