Have a 01 SRX with no spark. Have know idea what it could be. Don't have a tech. manual.
Any history of issues?
Thank you for Any GOOD help
2001SRX=Fast
I think that usually means that you have to clean up your coils.
yamaholic22
Could be a bad cdi, bad coils, bad stator, bad pick up coil, or even a shorted wire. Have a buddy with an srx that you can swap parts off of to test and see which part it is?
srxbully
i had the same problem.one of the wires coming from the pickup on the stator broke inside.might want to check there. if it's not the coil or cdi.
