stealth800
I have an M-10 in my Viper now and have not riden it yet. I'm trying to get it as set up as I can before the snow flies. All rear adjustments are set up per FAST recos for intial set up. Do I need to changes the front Ohlins spring preload? Thanks
vipertripplexxx
Lets see some pics of that bad dog. the avitar needs to be bigger!!!!! As far as the settings on your front suspension, your probably going to need to ride it, and see if you have enough ski pressure. I try to set mine up so that when it's on the garage floor(level and flat), the rear lugs of the track are starting to come off the floor. If you are a heavy rider, maybe more gap in the back, like 1/2" inch? I weigh 165, and like 1/4"-3/8". This setup will usually allow for pitching, without loss of control.
stealth800
I haven't been able to post the other pics, they won't download right. When I get it out of the trailer I will take some new ones and try to post them.Thanks for the info.
you will need a couple hundred miles on the skid to break in the springs on the m-10, then depending on how you ride go from there....CP
