snow3
I bought the grass drag kit from you. Should I run just the engagement shims you taped to the primary spring, or should I use more. Also, how cold of temps would you recommend that jetting? What would you reccommend jetting wise for 25-30 degrees? Thanks, Chad
ya, just run it the way it came, the shims should have been taped to the spring. This is a grass drag kit, not a snow drag kit.
snow3
O.k. but as far as jetting goes, I was thinking of the times where it is cold here and there is no snow...
YAMMIEGOD3:16
DON, NOTCHED THOSE HEEL CLICKERS I BOUGHT FOR ENGAGEMENT. HAD PICTURE YOU POSTED AND ACTUALLY HAD ANOTHER SET THAT WERE ALREADY CUT I USED FOR A TEMPLET. ENGAGEMENT IS 5400. MY 8BU SETUP WAS 5100. I THINK I AM GONNA TRY THAT. 3:16 (tony)
