Concept Carbon
Ok i was looking in the tech section and came across the viper fuel pump mod, is this necessary.
So in short terms im suposed to shim up the fuel pump with a washer or rubber gasget and fill the vent hole with silicon, but if you shim up the pump why do you need to fill the vent hole.
I have a bunch of scrap pieces of 1/8" and 1/16" thick rubber gasget material that is adhesive on one side. We use this at work to seal our aircraft ac duct/window mods.
would just a piece of aluminum tape over the hole work.
Has any one done this mod, any feedback will be apriciated
thanks Jay
thanks Jay
