New Viper!
laxs1308
Rochester NY
Hey, i just bouhgt a 2002 Sx Viper the sled is very very clean and has less the 2000 miles on it. I came with reverse. What updates if any should i do on it?
thanks alot.
:letitsnow :letitsnow
In 02' there was an update for the hood which required trimming off a little bit of the channel on the hood that goes over the belly pan and a little bit of the belly pan was shaved off as well. An update for the fuel pump which is nothing more than sealing off a vent hole on the bottom of it with silicone and putting a couple of washers under it to help keep it from freezing up. An update for the pull start rope which is a little nylon piece that slips in the groove on the chaincase to keep the cord from fraying.
Thats about all I can think of.
Tom
