SX Viper Risers?
laxs1308
Rochester NY
Has anyone ever put 4" RoX risers on there viper. I just bought them for my 98 formula Z and now i am selling that and am thinking about putting the risers on the viper....anyone has pictures?
Rox Riser
This is a 5" with Pro-tapers
Risers
NO MODS NEEDED. I SUPPOSE YOU COULD PUT THE BAR PAD BACK ON. i PUT ANOTHER 2" BLOCK UNDER THEM AND HAD TO EXTEND MY BRAKE LINE.
Bars
BoRnWiThBlUeBlOoD said:
m7 freak... so with that 5in riser and those protapers, u didnt have to change any cables? and is it the same or higher then the stock bars?? thanks
Nick
I DIDN'T HAVE TO EXTEND ANY CABLES. THE HEIGHT ENDED UP BEING THE SAME AS STOCK. WHEN I ADDED THE EXTRA 2" BLOCK I EXTENDED THE BRAKE LINE. SEE YA, MARK
Bars
laxs1308 said:
i dont need protapers or a new bar do i? cant i just use the bar thats on it?
IF I WOULD HAVE USED THE 5INCH RISER WITH MY STOCK BARS I WOULD HAVE HAD TO EXTEND ALL OF MY CABLES, BECAUSE OF THE DIFFERENCE IN HEIGHT BETWEEN STOCK AND PRO-TAPERS. MARK
risers
Okay, so my 4" risers will not fit with a stoke bar and cables. What is the easiest to fix that? buy a new bar? where can i get it cheap?
