BigMan76
Question:
I recently purchased a 1991 Phazer II which was setup to run in the mountains of Colorado; extended tunnel to 136", 1.5 camoplast paddle.
I also found an Aaen exhaust temp gauge wired to the windshielf fairing. It was connected to the exhasut pipe via a 1/8" diameter temp sensor, hole was drilled into stock exhaust pipe and temp gauge inserted.
Aside from just monitoring exhaust temp, what other functions, if any, would this serve?
I am a flatlander and have never ridden in the mountains.
Thanks.
Oh, and I need confirmation on this too; I can't run the pipe without wleding a plug over the hole, correct?
Thanks.
Thanks.
Thanks.
