15.6 or 14.5 rollers?
seca
st.john's,newfoundland. canada
just purchased a primary clutch for my 99 srx700 off a 03/04 viper. the viper has 14.5 rollers and the srx has 15.6 rollers. do i need to change them back to 15.6? what effect will the smaller rollers have? just engagement?
They will also lower rpm,s . makes your weight act like it has more mass.
it depends which weights you want to run. 8CA's and 89L's work great with the 14.5's, but any of the 8DN's will be way too heavy and aggressive to run with the 14.5's in most cases, so you will want that 15.6's back in there. Bigger rollers also raise your engagement because it holds the weight "tucked under" longer.
