I wrote it down and put the piece of paper in a safe place and now I can't remember where I put it. I just remember that it had 4.5 rivits in both holes and that is all I can remember. I did a search and I still cant find it. If someone knows what the setup is could you give it to me again.
slikRsrx
clutch
Go to tech section under ty members clutch set ups,Turk has alot of different ones posted there......good luck
yamaholic22
use your 8DN-20's with 4.5's in both holes, W-W-W primary, 51/43 or so helix with a green sec. spring at 60-70* wrap
Thank you, that is the setup I was looking for. I could not find that one on the tech page.
Link
here is a link to all Turks setups
http://www.totallyamaha.com/snowmobiles/aaTECH/tuning page.htm
Use the 48/40 advant-edge. it works great with that set up.
would you guys know off hand what helix I have that came with the Hauck #4. I bought the #4 off some guy for cheap and I didn't like it at all. I like the way the stock clutching was compared to the #4 setup. One other question, do you guys know where I can get that setup, best place to buy the springs rivits and helix?
