yamahajunkie
anyone run them on a viper? got a brand new set off of my warrior. looks like it will bolt right up, just wonder how it would track and ride out. anyone? thanks junkie
yamaholic22
Actually i believe the later vipers even came with those saddleless skis.
yamahajunkie
cool thanks for the info
xsivhp
You'll need longer bolts to get thru the skis and the spindles.
xs
xs
xsivhp said:You'll need longer bolts to get thru the skis and the spindles.
xs
Yep, all you need are longer bolts. I just installed a pair on my 02 viper. The keel is 3 times the size of the orig. 02/03 vipers. It should be much more aggressive.
Clarkster-1
- Jan 4, 2005
I run them on my Viper and they work great. I have have my sled heavily studded and it stopped the push problem in the corners along with 9 inch Shapper bars.
ViperXC
I have them too, he's right they are aggressive for the stock track. If you long track or stud they should work good.
03viperguy
they worked good for me
I have since sold them and gone to simmons. not because the saddless were bad, I just wanted to try something different and even more aggressive
