seca
if i wanted to long travel the front of my srx, will the 05 rx-1 shocks fit? if so what else will i need?thanks.
sxviper32
no. the four stroke shocks are 1/2 wider, so you would have to grind off the bushings on them or have modified brackets. also will need to be recalibrated for the sled because the weight on them by the sled alone is different. plus they are quite a bit longer than srx shocks so it would drastically change the geometry of the front end (would not corner like on rails anymore). you would need longer rods and possibly have to figure out where the mount for the shock on the trailing arm should go to get it back to the correct geometry. this is just what i've found out through my research on long traveling. hope this helps.
seca
thanks sxviper32, looks like i will stick with the ohlins extensions and maybe the bracket switch and flip!!
You can get a set of the rx-1 ohlins heim for the shaft end. They are about 1 inch longer, no travel, just ride height. Maxdlx
