YAMAJOHNNY
I am rebuilding a 80 SRX and going with replated cylinders. The consensus is to go with OEM pistons. I found some NOS/OEM pistons but no rings, wrist pins or bearings.Does anybody know if Weisco rings will work with the OEM pistons? How about wrist pins,clips and bearings? Kimpex makes a cast piston, but that scares me a little. Or to be safe, should I just go all Weisco? Plating isn't cheap so I want to be sure. Thanks in advance.
