Srx skid setup problems
RIVERRUNNER
Duluth, Mn
I just had my rear skid out of my 99 srx and I reset all of the shocks (stock)and limiter straps (25mm)to my riding style. I put skid back in. When the sled is sitting on level ground on a concrete floor only the front half of the track is touching the ground. It bolted into the sled fine and I set it up to specs. The rear of the track sits up about 1.5 inches. I can't figure it out. Is this normal? Does anybody have any ideas? Any info would be great!!!
That is how i have my srx set up as well, and that is how the setup looked even on the stock setup on the 00-02's anyway. Mine levels out as soon as i sit on it. I set mine up for ride and performance, not so that it sits level with nobody on it (as some people suggest)
Thanks guys. It helps alot!! I am 5'8 and about 150 pounds so the shocks setup stock should be about right for me. I also have adjustable transfer rods, so I think that the stock setting should also be about right.
