Viper Treats
Does anyone have a clutch set-up and a good top gear to run at 7000-10000 feet for an 01 SRX, just a short track.
Thanks,
VT
Thanks,
VT
cacsrx1
I used HC's with a few grams of heel weight to keep engagement down, rest of the holes empty. 51/43 helix with a green spring wrapped to 80. Geared at 1.86. Needed a little less helix, but overall it worked pretty good. This was at 10,000 feet with a 1.5 inch track.
pro116
Lifetime VIP Member
My buddy has my manual but yamaha show's all the different elevation set ups such as jetting,gearing,clutching.
Viper Treats
cacsrx1 said:I used HC's with a few grams of heel weight to keep engagement down, rest of the holes empty. 51/43 helix with a green spring wrapped to 80. Geared at 1.86. Needed a little less helix, but overall it worked pretty good. This was at 10,000 feet with a 1.5 inch track.
Is that a 41T/22T gear set? Also with a stock primary spring?
Thanks VT
