When putting your rivets in the clutch weights,do you slide them in from the left side and hammer them flat on the right side. That means peening them same side as the nut for the bolt that holds it in place.The right side hole is also a beveled hole.So it forms into the beveled part ..right.
FuzzButt
I did mine so that the head section of the rivet was on the beveled side of the weight I think. Sounds about right.
Honestly I doubt it matters as long as it is tight.
yeah well the rivets I used were small ones .85 and 2.7 and they hammed in nice into the bevel.Dealer told me last year to keep the peened side same side as the nuts on the bolts that hold the weights .
