EricMichael
I have a question about clutching my 02 viper with 8ca's. Do you have to run a higher preload spring than stock??if so i have a gwg primary,hauck orange and several shims. Also have an assortment of rivets , but was told to use 2.4 tip...anyone run this set-up in the winter?looking for an agg. set-up. how much top end is lost with these weights??better than stock?thanks guys
EricMichael
anyone using these?
i use them in the trails and have been very pleased
EricMichael
what do you run for rivets in your weights?also what are you using for a sled?
