troyhatt
is there anyone that could give me a complete parts list of what i need to make this upgrade on 01 srx. currently have the 2003 viper rear shocks not installed. and i do have the front brackets that raise about an inch off ebay.
i would like to raise the rear of the sled about 3 inches. dame thing sits to low. any tips??? thanks..
BETHEVIPER
Life Member
you need nothing but different spacers and to lengthen the rod a little.
do a search, this has been discussed in length about a billion times
get a set of adjustable transfer rods or a used set of a 98-99 srx.. they had the long version.
That's what I'm looking for as well. I've been trying various wording in the search but so far havn't come up with much info, lot's of people talking about it but so far I haven't found what all is needed. I'd really appreciate it if you let me know if you find more info.troyhatt said:is there anyone that could give me a complete parts list of what i need to make this upgrade on 01 srx. currently have the 2003 viper rear shocks not installed. and i do have the front brackets that raise about an inch off ebay.
BETHEVIPER
Life Member
here we go
you need nothing but to add a spacer to your tranfer rod end to extend the length of travel, or, buy long rods and mount them in the rear hole. your straps are long enough, they just need to be mounted in the differnt hole..
as for 3in higher, if it sets 3in higher when you are done, it is not set up correctly. for best ride, and handling, it should set about 1-2higher with you on it.
while the skid is out, do this http://www.totallyamaha.net/forums/showthread.php?t=30541
Wow, thankyou!!!! Very much appreciated!!!!BETHEVIPER said:here we go
I found this too, may be helpful:
http://www.totallyamaha.net/forums/showthread.php?t=23969&highlight=srx+long+travel
