vibeline
I bought a 98 srx700 a few years ago.
I rode it from my house to the lake about 1/2 mile.
I rode about 2 miles east 1/2 to 3/4 throttle everything was great.
I did a U turn and put the flapper to the bar.
About 3/4 of a mile speedo was pegged, I was smilin, about the 1 mile mark the belt exploded. (I was pissed).
2 out of three of the clutch weights were gone (they vaporised).
I put stock clutches on it and it has been fine since.
There is a (39) marked on the helix.
The secondary spring is black with a pink stripe
Weights?????
The primary spring is red.
Weights?????
Those weights are HeelClickers and primary spring is most likely HC red.
Secondary spring looks stock Yamaha pink (pretty soft).
You have Maxximum performance Roller secondary. Helix is 39deg.
EDIT: Pink is pretty Stiff not soft.
vibeline
Maxximum out of business
I found an old post from Mrviper he suggested w/w/w primary,
green secondary, 51/43 helix and stock weights with lots of tip weight.
I'm looking for top end lake running.
Who makes a 51/43 helix that will fit in that machined secondary?
Other parts I have are:
a stock helix part# 38BV71
black with silver dot secondary spring
stock secondary clutch
8DN00 Weights with 4.5 gram weights in both holes
Any other suggestions welcome.
You can not use (normal) 51/43 helix with roller secondary. It's way too steep (and don't fit in). These instructions are for stock (button) secondary.
I believe MrViper can give you right agle info for roller sec.
That silver secondary spring is quite tight for radar-runs, try to find green from somewhere.
x2ryder
A pink spring isn't soft it is quite stiff. It is stiffer then a silver.
x2ryder said:A pink spring isn't soft it is quite stiff. It is stiffer then a silver.
You are right, sorry.
srxbully
he said he has the stock secondary.
