HI. I have a 02mod Srx whit hauck 780 bigbore kit.... Now i want i lighter! Where can i find lightweight chassie and div parts?
valin
Nice wheels. Are they 8", or 7's?
8".... Im thinking to but 2 alu wheels in the middle, and remove wheels who you can see from the side..
valin
did you have to remove that shaft that goes between where your transfer rods bolt to the rails for clearance? I figure I'll have to do that for the inner 8" wheels.
I'dont know... Have just bought the machine..
If you weight those alu-wheels, those are heavier than stock plastic ones... Just for your info.
Looks good anyway.
Looks good anyway.
srxbully
& i'll trade you my plastic ones for them also if you want to go lighter.lol
srxbully
get a viper seat.much lighter
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
There are several things you can do to drop weight. As mentioned above, the viper seat will drop 2.2 pounds compared to the stock srx seat, We sell a light weight front end kit in polished heat treated aluminum that drops 12 pounds without ours skis and 16 pounds with our skis. You can get a lightweight rear suspension for those sleds which is also going to drop 15-25 pounds depending on what you go with. Lightweight hood you can go with. Lots of stuff. Let me know if you have any other questions. Thanks
x2ryder
Where can i get a set of those wheels?
A boss seat drops I think between 7-10 lbs's.You canb use some viper aluminum front bumper braces to replace the steel one's you have to mess with them to make them work and the stuff 200srx listed.it's all little nic pic stuff that add's up.
srxbully
yeah well definitly a boss seat if money isnt a factor.
