136" SRX Clutching
BBlueSRX
michigan
Any suggestions on clutching? 98' 136" SRX Stockity stock with a silencer and long travel front and rear.
Thanks in advance
Tim
As long as your at 8300 rpm at wide open throttle you won,t gain much on a trail sled.
it was completely stock clutching w/ 3136 miles w/ 121" skid and the primary had major cracks in the inner sheave. stay stock Turk? It may have been revvin out to 8400-8500 and it ate through a couple belts (primary might have caused this).
If your eatin belts check alignment & centre to centre.
