Is this a Viper or SX Rear Cooler?
viper7mi
Michigan
Is this rear heat exchanger cooler a from a Viper or SX?
Is there a difference?
Someone please look at their SX and Viper with the new kit to seewhat this is?
I think your right? Yamismurf bought the viper kit and the his looked like it mounted to the top. His kits tubes go up if laying on its back and mine go out?
thanks
That's off an sx. Like i said the srx and viper ones are the same. The 02's and 03's didnt come with them stock though, but a great add-on to put one on.
Viper Upgrade one is bolt on/ SRX exchanger on a Viper you need to relocate the coolant bleed hole on your tunnel. Check ebay pretty sure theres a Viper Upgrade one at like 60 bucks right now.
daman you needing a rear cooler. I may have one laying around somewhere. Let me look tomorow. Maxdlx
2stroken said:
I was told the cheaper viper ones that yamaha was selling were different than the SRX.
Yes they ARE slightly different in that the coolant bleeder screw is in a different spot, THAT IS IT
