snow3
I need a setup for a 01 srx 835 bender big bore.. Clutching, helix, springs, 40-10 heelclickers, gearing. For 500' on grass and snow... I am running 240 chisel tooth studs..
x2ryder
Get a hold of either Buffalo Bob, Turk, or Mr Viper 700. Or call Bender at (716) 941-5840
bufalobob
is it case ported? 38 mm carbs or 33? bender pipes? roller clutch or button? high compression or stock? timing key cut or stock? old style clickers or newer?
bob
bob
call my cousins and tell them nik delsordo sent you, they will give you all the help and even install and set up your motor, suspension, clutching. trust me they do very very good work ask many people about them. DoktorC knows them very well. they where at hay days and won 6 out of seven races they participated for. give them a call and tell them what you want to do and how fast you want to go, they will tell you what you need where to find it (if you don't want to buy from them) and how and who to set it up.
iantomasi racing
gerry iantomasi
905-263-4868
tell them nik delsordo sent you.
trust me you will be more than happy if you go with them
iantomasi racing
gerry iantomasi
905-263-4868
snow3
It has 33mm carbs, stock compression, stock timing, not case ported, bender pipes, button clutch...... newer clickers
bufalobob
gearing - 20/40
plugs - .020
mains - 165 - all
pilots - 60
needles - #4
fuel screw - 2 out
v-force 2 - soft
oil cable - 20 mm
h.c. - 60.4 grams ( tip - 3.3, inner 4.9. heel 3.1 )
h.c. spring - red
15.6 mm rollers
helix - bender 9870c
sec. spring - bender white/blue or red/yellow @ 60*
bob
plugs - .020
mains - 165 - all
pilots - 60
needles - #4
fuel screw - 2 out
v-force 2 - soft
oil cable - 20 mm
h.c. spring - red
15.6 mm rollers
bob
snow3
Thanks for the replys.. What kind of times can be expected with that setup, Buffalo Bob??? I have been running 162.5 162.5 and mag 165 for mains....
bufalobob
jetting changes based on air density. 165 is safe all around for 500'. should run mid 5's.
bob
bob
snow3
Thanks to Mr. Viper we have a stock srx running 5.6-5.7... I was hoping for 5.2 or so. Thanks for the info though.....
bufalobob
times are based on tuning ability ( engine & suspension ), weight & experience. the 835 you have is a trail motor ( around 175 hp ) - it will run lower than mid 5's but it would either need additional engine work or about 75 lbs. removed & aggressive suspension work. if it runs 2/10's quicker than your stocker than you should be happy.
bob
bob
