Balancing clutch? Turk/mrviper others
norwegian
Well-known member
norway
I am going to replace both my clutch sheaves because they have heat cracks in them. My questions are:
1) Can I first replace the outer sheave and run it with the inner hauck overdrive (this sheave does not have heat cracks, but the stock one I am replacing does, so therefore it isn't in use)sheave as it is now? Do I need to balance the clutch?
2) When I am going back to heelclickers, I am going to replace the inner sheave with a stock sheave (totally new). Do I need to balance the clutch again???
What am I supposed to do here?
I don't like the idea of anyone cutting my brand new sheaves with no warranty!
But I heard that if you dont balance them the clutch will break your crank?
