How many of you are running your mt. vipers or MM in the lower rear mounting hole?
Mtnviper
When I was still using a Yamaha skid, I ran mine in the lower hole. Helps in deep snow, for running board clearance. This is most noticeable in wet heavy snow.
bolin22
another for the lower hole.
mightymg
x3 for the lower hole
A K MtnViper
lower works for me to.
LoneViper
Lower hole increases ski pressure.
MtnMax600
I moved middle and rear to lower holes when i went 151.
nben
and one more.....
1slo_MM
middle in lower hole, plus MPI drop brackets in lower hole...
OK, so if you go with the lower rear mounting hole, what is the best set-up to lessen ski pressure? Mine is in the lower hole, front straps all the way out, front skid shock stiffer, OEM transfer rods 50/50 with me on it, and the front of the skid hits the ground first. It does amazing things in the powder, especially climbing. On trail is pretty good too.
1slo_MM
I also have the MPI weight transfer elim kit.. it rox in the deep pow
transfer enhancement kit or a non coupled rear suspension is a must, if you just put the suspension in lower holes it will have a strange geometry, if you imagine ski-front -frontskidshock- rearshock, the skid will not be flat on the ground the rear will dig through the snow
Getchuck,
I don't think that is the case on mine. I swapped out the OEM powder skis for the simmons, which are lower, and that raised the back of my skid. Using the lower mounting hole basically set it back to spec.
Mtn-Track said:OK, so if you go with the lower rear mounting hole, what is the best set-up to lessen ski pressure? Mine is in the lower hole, front straps all the way out, front skid shock stiffer, OEM transfer rods 50/50 with me on it, and the front of the skid hits the ground first. It does amazing things in the powder, especially climbing. On trail is pretty good too.
I had the rear of the skid in the lower holes and simmons skis last year and had a lot of ski pressure.
Dropped the middle to the lower hole this year, and put on a set of the new yami powder skis and now I don't have the ski pressure, almost too much lift.
Gonna tighten up my front straps a bit. After running the yami skis this year, I won't pay the price for simmons, they are twice as good as the simmons, my opinion.
I believe that the skids are different on the '05 Mountain (mine), so the set up is different as well.
