primary clutch
you know they probably wouldn't HAVE to be in there, but im sure they're in there as a safety factor in case something would happen to the bolt, like the nut backing off for some reason. If you have them i dont see any advantage to not putting them in, just an added safety factor so the weight can't let go.
Cool I'm just starting to tune my primary with a set of h/c and I just didn't wanna have to put them in and then take them out every time I change weight. Once I get it set up I will install them.
