rideamtnviper
How in the heck do you get the impeller shaft and impeller apart? Can this be really rusted together? Is this shaft splined or can you twist on the impeller to try get it off? I have the bottom end apart and have no good way to hold the impeller shaft from turning.
Does both need to come out?? whats the problem your having??
can you put your sled type in your avatar..
to get the impeller off there's a small bolt in the end of the impeller
(shaft) you may need to hold the clutch to get that bolt off,yes
it's splined.
it's splined.
rideamtnviper
Got it off with a little heat. Just tiddying up the bottom end before the season. Crank, Seals, ect......
