all throttle no bottle
can you bore the cylinders on a 2000 SXR 700
sure. then they need renicasiled after boring them.
Junior
it's not that much to have them welded before bored then nicked, then you're running a stock size piston. Oversize pistons for those sleds are not exactly great for availability.
Unless ofcourse you're bigboring it, in which case go nuts. Wiseco makes a piston specifically for that app, just order the pistons, ship the whole kit kaboodle to millenium and your bigbore will come back in the mail shortly later. Only thing you need to do aside from that is machine the head, or go with a billet head.
thanks guys
