Phazer issues
8vo fan
Hersey MI.
I finally got to drive my Phazer yesterday. I installed boyeson reeds in the spring and had it running good. The temp was in the thirties and I was running lean. From what I understood the reeds wouldn't require a jet change. It ran best below zero before the reed change.
I also need a clutch spring. I read a post that PSI recommended an o/y spring. I can't seem to find this spring for the yamaha clutch.
I also am interested in the v-max 600 carbs. From what I can tell these are a dirrect bolt in. Am I wrong?
