ExpertXViper
Alright IDK how the he** this happened but I went to adjust my fuels screws for the first time EVER. 2 outta the 3 adjusted no problem at all but for some reason the middle one will not budge. Has anyone had this problem or have any suggestion how to go about getting it lose. Cause IT WILL NOT MOVE.
auji700triple
hope ya gets it fixxed, TTT
if you have a cordless drill, with a bit that fits tight in the screw head, set it low enought that it ratchets. Slowly turn it up in power, and see if it will vibrate it loose. I have a spare fuel screw if you end up needing one. Maxdlx
ExpertXViper
Well I was hoping with the things I tried, but my hopes were shot down. Gunna try your idea Paul and if that dont work theres no way to fix this problem. Just gunna end up buying a whole carb rack. The cause of this is aluminum to aluminum design caused corrosion which in reality is just as bad as steel to steel. Got my fingers crossed one more time. Thanks for your input Paul.
ExpertXViper
Well the ole cross your fingers thing didnt work. So it looks like I'm doin things the hard way and buying a rack of carbs. This whole running pipes ordeal on my sled is really starting to kick me in the ***, TIME and MONEY WISE. One word for that GAY.
Expert there is a set on E-bay Item number: 300059102499 if it's any help.
you can try to drill a little hole and put a small extractor inside
Take the carbs off and drain them. Heat the area with a torch and cool it down quick with a wet rag. Be carefull heating it, not too mutch or it will melt. The heating and cooling should free the bolt.
ExpertXViper
Been there, tried that. I work with metal for fun I know the tricks of the trade. But I have delt with alot of aluminum to aluminum corrision, heating it doesnt do anything. But I did get it out but by brute force of my cordless drill. LOL broke a decent size peice off, where the screw threads into the carb body, so if offically F'ed now. And it wasnt coming out any other way than that, I tried every possible angle and idea. But thanks for the ideas fellas, but looks like is being delt with the expsensive way.
Hey will a carb body off of a 97 700 sx work. I have a rack of them, if they will. Look up B2SO he has a set of viper carbs. They are drilled for dial a jets, but you can plug the holes. Maxdlx
ExpertXViper
Not sure on the SX deal Paul, but gimme like 2 days cause I'm bidding on a set on ebay. If it goes over my limit, I may drop ya a line. Thanks
B2SO
- Aug 18, 2003
maxdlx said:Hey will a carb body off of a 97 700 sx work. I have a rack of them, if they will. Look up B2SO he has a set of viper carbs. They are drilled for dial a jets, but you can plug the holes. Maxdlx
The man is right , i do have a set of carbs , they have one hole per carb drilled in the top of the carb collar , , the rubber boot from the air box covers the holes and they work fine , i didnt even plug the holes but you could , i would sell them to ya for $50 shipped to your door , by the way the only reason i have an extra set is cause i had the same problem you have now , i tried drilling out the screw ...and i fu$*E the carb up .... oyh well ...good luck and let me know , i can have at your door by thursday ...
p.s. THanks for the plug Paul
ExpertXViper
B2SO: Its is a complete rack correct??? All the fuel screws actually move with no issues? No other issues besides the wholes for dail-a-jet???? Let me know on that note, cause I'm more than interested. Thanks Brett
P.S. Sorry for the off the wall questions but just makin sure and double checking. I'm anal when it comes to fueling parts.
B2SO
- Aug 18, 2003
yup
yup , everything is there and works well , the only things you will need to do is put your main and p-jet in and your good to go , air jets are there , even has the tps on it , basicly i pulled them off the sled took out the jets to send to maxdlx and set them on the bench , and just cause you live in driving distance and if i didnt get my cash i could come find ya
, i will send you the carbs , you can check them out and if you like them send me the cash if you dont want them just send them back to me . if that sounds good just pm me you address and i will send out tomoroww ...
Ride on !!!!
Larry
Ride on !!!!
Larry
ExpertXViper
Sounds good to me, just so everyone knows on this site. There is one thing I do, do and thats pay any money I owe to anyone. I dont play around with money, cause I know if that was me, I'd be snapping and heads would roll.
B2SO: You have a PM, thanks alot
