prostock700
- Dec 30, 2005
I was wondering if polaris gears will fit this sled and if so what size shaft and how many spline for the top gear? what is a good set up for this sled? I have removed head gaskets (all but 1 !) notched the reeds, bored the silencer stock clutching.
Thanks.............
Thanks.............
prostock700
- Dec 30, 2005
gearing set up i mean....
Twin or triple...& what year??????? They made 600 twin & 600 triple sx,s & the difference is huge!!!!!
prostock700
- Dec 30, 2005
1999 Triple, sorry...
Stock gearing is fine. Just add more mass to the stock primary weights to get proper rpm,s. Change inner to a 4.5 gram rivet & you will be very close. $5 clutch kit!!!
I recommend a 2to1 gear ratio, 20/40 with a 68 link chain. Chain runs real straight for less friction, you need all ponies on the ground with that motor.
prostock700
- Dec 30, 2005
Why such a low ratio? I have 21-39 in it now. Will polaris 15 wide gears fit this sled?
