hos
- Sep 28, 2005
Already did a lot of searches on this, but can anyone tell me if I can utilize my heims off the SRX to put into new Viper radius rods? According to Yamaha fiche, I know the tubular end with the bushings are the same size. Just don't want to drop $200 on heim joints. And yes, I know you have to flip flop ends compared to the Viper. Mounted an M-10 and front mounts (w/ stock KYB's) from Hauck, but the front end still has to much rake. I've got the viper shocks, just need the rods and radius arm.
you could just use xtc vmax rods, they are longer then the srx and will be direct replacement to the heims you already have. The viper uses a differnt size heim on the upper rod on the outside.
