yamaman700
Looking to install a temp. guage on my MM700. Any sugestions where I should install the temp. sending unit. I was going to cut the coolant line and install a "T" but can't figure out the best place for this.
Thanks...
Thanks...
temp gauge
did you ever find out how to do it i'm interested to do that to
yamaman700
No I haven't figured it out. The last time I looked at it I was considering mounting the sending unit where the temp sensor is in the cylinder head now. I will need some new metric adaptors for that.
jwiedmayer
I tapped mine on the bottom of the head underneath what looks like a thermostat housing. There is a casting mark there. Also if you tap into the line you will have to run a ground to the sensor.
yz125mm700
mine just replaced the stock sending unit, now i only have the gauge and no warning lite.
