kysledneck
Hit the link, look at the engine pic is that a radiator?
http://cgi.ebay.com/ebaymotors/YAMA...ryZ42599QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
sandmanmike1
I wonder if they smoked a heat exchanger and did some redneck engineering.
kysledneck
Well seeing it is out of Indiana & have bought 2 my self from there .... Yea redneck engineering for sure! You would think some air flow would help!sandmanmike1 said:I wonder if they smoked a heat exchanger and did some redneck engineering.
I hope that's not the only thing cooling that thing!!!! WTF!!!!!!
kysledneck
I was stairing at the pic & just saw there is no air box either! This could be like a game "find out what is wrong with this pic!"
NYsledneck
Well he probably needed room to fit the radiator under the hood so something had to go.....Way too funny!
kysledneck
Just the experience I have had with my 2 sleds from there! IN is fine! Hell I live in KY! But I keep the sleds as new as possible!sxviper32 said:hey... wow, whats wrong with indiana! "redneck engineering"... we have two of the best engineering schools in the nation here! but ya... that sled has seen better days.
woolyviper
sometimes sleds used in grass drags will have that type of radiator installed.
There is no resivor bottle either. He took it out and looped the hoses together. Maxdlx
jwurl
I can see the radiator is from a 76-80 SRX 440 .. Jeff Wurl
2001SRX=Fast
lol this sled looks like it is gonna be a doozey
NYsledneck
so who`s bidding on this weapon? Bet it`s a steal....lmao
kysledneck
MY bad its from OH! My 700 was a OH sled, was about as bad as the two from IN! LOL! Wrong belt, busted primary, skid shot, bad skis & the corn stalks I pulled out from god knows where!sxviper32 said:just had to give ya a hard time!
Concept Carbon
check out the sweet stud pattern, im suprised there actually studs and not misc nuts and bolts
FuzzButt
Well that is going to be a real fun project for some unlucky purchaser.
The bid is up to $520 or so but not met a reserve yet. Got to wonder how high the reserve is if $500 is not enough to cover the "trade" for a 4-wheeler.
Maybe we should start a "What is wrong with thiese pictures" thread and post our "how to fix your recent ebay purchase mule" thread seeing as how someone is going to need a bit of help with this one.
Ideas so far on a quick glance:
Old sled radiator under hood plumbed god knows how may be there for a fix for a thrown stud into the front cooler. The front head drain is plumed around then to an elbow to the rad then back out to the read head input so there is no other working plubming on this vmax.
It will run fine ok but a bit lean till the foam socks fill up with fuel spiting out of the carbs so I'm thinking it is a short duration rider.
Ice drags are out. That pattern is almost like having no studs at all.
Looks like it goes thru plugs since the spare holders are empty.
A fix for the new "Coil bracket" might be handy. I still can't fine the CDI unless that was it wedged between the oil bottle and the new radiator. It is always good to have loose wires down by the jackshaft.
The lower left radius arm may be a bit bent.
The lower right radius arm is either missing the red cover or just missing alltogether.
Looks like someone painted the foot area of the tunnel red.
Now for the good news.
2400 miles
trailing arms look stock and not bent.
2400 miles
kysledneck said:Wrong belt, busted primary, skid shot, bad skis & the corn stalks I pulled out from god knows where!
Sounds like the condition I woke up in last Sunday morning.
I think that might be a heater core being used as a rad??
kysledneck
Now that is funny!Bischof said:Sounds like the condition I woke up in last Sunday morning.
Dfunkdf
That sleds is like 30 minutes from i need to go see it and laugh at this guy
