Need 12V wire color and location that leads "TO" keyswitch - srx
Rambunctious
Holland, Michigan
I Need 12V wire color and location that leads TO keyswitch - 2000srx
still need help with this
I added a battery for some accessories, and i need to tie to electrical system. need to tie in before key so engine doesn't keep running due to battery, when key is off
thanks
ramb
I dont think you can just add a battery to a sled if it did not already have one. A battery is D/C and the sled is A/C. I think you may need to add some other parts?????
If you add a diode in line, the power will only go one way.
BUT, I still think it's a bad idea to try and charge a battery
with the SRX's 300watt system being so finicky
I found in the book, that adding more than 30watts of accessories to the 300w system
is not recommended & could cause multiple engine performance problems.
