Clutch and jetting setup?
1fastmax
halton hills, ont, canada
I got a 94 vmax 600 with these mods, and not sure what i should do about my clutch and jetting setup can someone help me please? thanks alot.
MODS
Carbon Tech reeds,
Thin head gasket,
Airbox mod,
96XT secondary with stock spring(green) set at 70,
Primary spring G.P.G,
and ill be getting my PSI twin pipes in a few days,
Please help me thank you very much. :2strokes:
sorry one more thing whats the best gear setup. sorry 1/4mile runs and abit of jumping.
I'd start with a 160mj, check your plugs. You may end up with 156.3mj with good fuel.
PSI clutching:
8AY-40
alum rivet
pnk/pnk/pnk spring with 3 shims
I used a RPC spring Yel/Red = 50 / 116
shift at 8100 rpm.
PSI clutching:
8AY-40
alum rivet
shift at 8100 rpm.
What setting did you have the needle position at?
