rideamtnviper
Anyone know the code for 8 repeating flashed. The manuals I have do not show this.
I unpluged all the wired to the handlebars and it still was blinking. This flashing will start right away while the sled is warming up.
Thanks for the help!!
8 is thermo sensor short circuit or disconnected.
TimeBomb
had the same problem, check your connection on the plug to the sensor on the head, that is where my problem was.
rideamtnviper
The connector looks good - how was yours bad? The cable it connects to is not shorted either.
The sensor is hooked up and my sled had been cooled down for 90 minutes.....the resistance of teh sensor is 2349 ohms. Any idea if this is bad or good? When I unplug the sensor it or plug it in the 8 repeats the same.
TimeBomb
on mine, the connector was loose. i ended up putting a new one on plus i added a temp gauge just to be on the safe side. the connector should have a tight/snug fit.
rideamtnviper
anyone know if 2349 ohms = bad sensor?
TimeBomb
yamaholic22
On my viper at one point the wire broke where it goes into the temp sensor, did the same thing. I have seen a few other vipers with the same thing.
I had that same problem while up in eagle river Wisconsin. i took it to Heckels and the guy told me that there was an updated coolant temperature connector.. there was some problem with the connector the wires were NOT broken,, i replaced the connector and it worked fine!!!
rideamtnviper
Thanks for the help..... The wire was broke right behind the connector. Took a while of messing around to get it figured out.....(I took the harness out...
Thanks again!!
Thanks again!!
