chilli
I want to get the top driveshaft out of the chaincase, so I can remove the chain case all tobgether.
If I remove the circlip holding the upper bearing in, will that allow me to remove the chancase from over the shaft?
How do you get the top shaft out?
bluewho
If all the bolts are out you should be able to put a prybar behind the chaincase and pry out without removing that bearing c clip if it does not pry behind the rotor and make it free.
chilli
so the circlip is simply holding the bearing in place?
chilli
I already have the lower driveshaft out, but the upper seems to want to come along when I pulled out the chaincase
bluewho
The rotor is stuck thats all tell me how did you get the cog axle out ? you dont have outside drivers?
chilli
i removed the collar bearing on the speedo side (with the 2 set screws) then pushed the shaft trough into the tunnel, then just removed the whole shaft
I want to remove the top shaft now, but it sems to be stuck in the top bearing on the chaincase side
bluewho
Yeah the parking brake is holding against the stuck roter thats all.Tap and pry it will all slide off together.Go back out to the garage and try lol.
mulderdad
If it still won't come off, get a bigger hammer an bar. It has to slide off.
Be careful not to lose the locating key under the disk brake.
And BE SURE TO PUT IT BACK IN when you go to install the rotor again!
I lost a very good snap-on ratchet in the bush the day I put it all together and the brake rotor turned on the shaft.lol.
bluewho
Hey mul you throwing tools.throw them my way!
