HIDs anyone?
Roost 'Er
Flamborough, ontario
Thinking about for my birthday throwing a set of HIDs in my srx...has anyone else done this and how did it work... because its a 300watt system i dont think i will have any trouble with lack of power...
Anyone tried this before and how did it work? general thoughts?
I tried it before and failed. I have all the stuff to try it again. I'm just finishing buying all the parts. The last time failed because I could not figure out the charging circuit and I only had low beam h4 hids. Now I think I have a handle on the charging and I purchased a Hi/Lo hid. 300 watts has 25amps max. The HID require start up of ~10amps a piece. So you should be ok unless you try to fire both at the same time.
