Concept Carbon
ok im gona be changing my chain case bearings, do i need to lube them at all, or do they come ready for install, also should i change the seals.
I just pulled my track off, holly crap pain in the ***, not much room on the viper to move the track around the drives had to grind the rivets off that hold the bearing housing thinngy.
kysledneck
They come lubed I do not see why you would lube before installing, I replaced my seals you are right there if you do all that work & have a seal leak time to do it all over again! I bought a inside bearing puller from harbor freight to get the bearing out of the one in the outer case worked great $10! Had to do the same on the speedo I used gasket sealer when putting it back together!
Concept Carbon
thanks i will push the bearing out with a arbour press at work or pull it.
