Traildemon
- Jul 24, 2003
Anybody have a clutch set up for a stock (except thin head gasket) 98 600 XT (twin) . Just want to wake this sled up a little without spending much $. something to do while waiting.....
kysledneck
I have a 97 twin Sled was bought w/ a bender kit in it, Orange primary spring from bender & not sure on the helix angle , 4000 rpm engagement runs great! Also go to the tech pages there are several set ups!
jwiedmayer
I just purchased another 600 for my wife. So I'm going to be doing some set up work my self. The clutch page is http://www.totallyamaha.com/snowmobiles/aaTECH/tuning page.htm
The 8ab is the same profile as the 8ca.
is it a sx or xtc?
Traildemon
- Jul 24, 2003
clutch set up
IT's an XT (XTC w/crappy steel shocks, but now has SXR shocks) I found one set up on that page ,the other is a 99 - is that the tripple ?
if you want a cheap upgrade put in a 48-42 helix and keep the stock springs that's what came in the clutch kitfrom maxximum performance for the xtc/xt.
jwiedmayer
99 is a tripple. The Maxx kit was pretty good. I liked the 8ca wieghts.
The set up I was talking about is for 97-99 vmax and xt,xtc
Trail Demon this was a set up on a 96 vmax 600 xt not sure if it will work for you wait for someone to chime in about these figures.
Primary Weight- 8ab-00
Base or first hole- 2.4
Primary Spring- GPG
Engagement shims- 1
Secondary type- Stock
Helix- 45/41
Spring setting- 70
Primary Spring- GPG
Engagement shims- 1
Helix- 45/41
Spring setting- 70
trail demon I have other setup's better but you said you didn't want to spend much money.
jwiedmayer
That's the one I was talking about too. With the head gasket mod it was pretty quick. Back in the day I remember smoking my buddies new mxz670 off the line to about 70 then he would creap by.pro116 said:if you want a cheap upgrade put in a 48-42 helix and keep the stock springs that's what came in the clutch kitfrom maxximum performance for the xtc/xt.
Traildemon
- Jul 24, 2003
clutching
Pro, I wouldn't mind buying maybe a couple springs, helix, or weights. I think I have some 8ca's left from my old SX700
