heel clicker clutch kit
92vwgti
quebec, canada
ok so im in the market for a complete clutch kit. im currently looking at the heel clicker kits they are 219$ us heres what it includes
The Yamaha kits include:
(3) Direct Bolt-in weights
(2) springs
(6) Nylon centering spacers for pin
All adjustment hardware needed
Instructions
Heel Clicker Decal
does it have everything i need? i really have no idea what im doing and its my mechanic that will be doing the instalation. alone with this will i have to buy change a helix? well give me any simple easy advice you have or if you have a used kit tell me
thanks
You need helix and you need to measure your primary rollers. Need to be minimum 15mm. Check HC topic from tech FAQ
thanks will check it out..what angle helix should i go with i do mostly twisty trails with some lake running i just looked at the specs and my rollers are 15.6mm
your rollers are fine. Look for a set of used 40/10 heelclicker weights with the red hc primary spring; should get a good used one for 1/2 that price on here. 48/40 advantedge helix work great or a dalton around a 50/38 also works well.
